Hello!
I have been following this page for YEARS AND YEARS and finally have a real reason to post, as most of my answers have been found through searching. I just purchased the Pinnacle Black Label Diamond Paint Coating. It seems as though most of the cars that I end up detailing are black. I have someone that wanted to try a coating on his black '67 Vette. He has always been happy with my work, however, I have a couple of questions. Prior to using the coating, I will wash, Iron-X, Clay-(optional) and then use M205 with the Meguiar's MF 5" Cutting Disc, as the paint is in very good condition from the last time I worked on it and it is RARELY driven. The only reason I'm even using the 205 is because every time he uses his car cover, he seems to get marring (hence the want to try the coating). Am I able to put another polish or glaze on once I finish with the 205 and THEN use the Black Label Surface Cleansing Polish? I know I can top the Coating with something like Pinnacle Liquid Souverän to make it even better, but the real question is, what can I do to enhance the blackness prior to using the coating or the overall deep black color? Thank you in advance!!!
