Sticky Cobra clay bar mitt
Pete L
Used my new Cobra clay bar mitt for the first time last weekend. I followed the inclosed instructions and WOW! It worked. It saved time and did a great job. Afterwards, I rinsed it with clean water and set it on a terry towel, rubber sied up, to dry. Now, it's sticky. The instructions say not to use if sticky. Anyone else experience this?
The NanoSkin ones get sticky too, but I still use them with no problems.
Agreed.
I have the Cobra mitt, Nanoskin sponges, and Griot's Synthetic clay. All of them feel kind of "sticky" after the first use.
It's after you knock off the initial coating using it on glass.
You're good to go.
Did you let it dry in the sun?
I accidentally ran my two clay mitts through the wash the other day and now they are sticky again.
They also went through the dryer. I about freaked out at first but they were not stuck to anything. One was a little folded against itself but pulled apart fine.
What kind of mitts?
I ruined 1 Nanoskin mitt and almost ruined another after leaving them exposed to direct sunlight. This is my new 1 that I nearly ruined but managed to salvage by putting it in the fridge to try to reverse the melting that had begun to happen.
If you look at the right side you can see it had started to melt. The left side is as it should be. Worst part is I didn’t even use it that day, it was simply laying on top of my detailing bag exposed to the sun. These things are sensitive!
Here’s the ruined claymitt on the left...
Not too long ago I detailed a black Infiniti and when I began claying it it was so extremely contaminated that I was nearly cringing at my mitts lifespan being shortened from that dang car... So I went and grabbed the my other mitt [the 1 on the left] and clayed a few of the worst areas with it.
Btw I was working at night, so I couldn’t really see much but I was going to compound the vehicle the next morning so it didn’t really matter.
I woke up the next day and came out to start on the car and as soon as I saw the paint there were several areas that looked as if someone had taken a brillo pad to the paint. I was like omg what in the heck is going on here?! It took me about a minute to wake up and remember what I had tried the previous night... Oh boy that bad claymitt obliterated that paint! Marring from hell!lol.
I used it on my windshield first as recommended by the instructions. After use, I rinsed it off and set it on a clean terry cloth (rubber side up) in the garage and out of direct sun/heat. Now it's very sticky.
My nanoskin sponge gets sticky after I clean the face of it with OPC, and I’ve never really even given using it a second thought.
I didn’t even know them being sticky was a bad thing, lol. I just assumed that’s how the surface feels after it’s broken in and clean. After a few sections of claying my sponge usually isn’t tacky anymore. Like half the hood and when I go to clean the face of it off, it feels fine to me.
Does anyone have experience with the Blackfire mitt? It’s significantly cheaper than the cobra but looks the same. Anyone no why the price is only $25?
I've noticed the same thing.
So... what I'm hearing is that it's not uncommon for the clay mitt to feel sticky and still work. However, there is a chance that a sticky clay mitt may scratch the paint. ???
They are suposed to be a sticky after the break in on windows. That's one reason they pick up contaminants that is embedded on the paint. And one reason is to use a quality lubrication when useing it. Just like you would with a clay bar.
And inspect the clay alternatives before starting to use them. So they don't look like Eldos clay mitt on the left in the pictures. Then they are doing more damage than it's usefull.
The clay mitt you accidental had in the sun Eldo. The right part of the mitt looks like it has been getting the clay almost melted away. Have you tested to use that and how did it work? Or was it that one that did the scratching or was it that one on the left in the pictures?
What kind of mitts?
EagleOne.
I think they quit making them, now I’ll have to buy some other off brand.
I did just use it again today on a Toyota and it didn’t seem to mar at all.
Nobody for the BF mitt then? Affordable.
