Storage Ideas Needed - Foam Canons, Guns, Wands...
Manhattan
Member
I'm in the process of redoing my "wash station" - removed beadboard, drywall, insulation to locate wires (the main service/panel is on the outside wall here), moved one outlet, added one more... Went back with 3/4" Baltic Birch plywood and left the screws to make the studs easy to locate. Still have to trim it out. Oh, and a couple cabinets for chemicals, MFs, polishers, etc.
I decided mid-project to use French Cleats on the lower section. I use them in my shop (other end of garage) and love how you can add and relocate things.
In this pic, only the electrical cord and pressure washer reels are "permanent." everything else is utilizing the cleats. The vacuum hose real is too small - will get swapped and moved a bit, vacuum scooting a bit left, etc. etc.
The top rows will have a shelf (for in-use stuff that's stored above in the cabinets) and to store pressure washer accessories. This is where I'm kinda stuck. I might use those wall-mounted quick-disconnects, but wonder if they're more of a hassle than convenience. I want the area neat and organized but not at the expense of ease of use. I need ideas, tips... How are you guys storing your guns, cannons, wands, etc.
Thanks!
Side note: Of the 62 forums, which would have been the ideal forum to post ^that^ question?
The top contenders were...
  • Ask your detailing questions
  • Tricks, Tips and Techniques
  • Tips, Techniques and How-to Articles for Interacti
  • Auto Detailing 101
  • Off-Topic
Thanks!
