oneheadlite
- Aug 20, 2015
- 1,795
- 100
Wondering if anyone has any suggestions for a container to use/store rinseless wash.
So far I've just been using 5 gallon buckets with Gamma seal lids, but since I most often just use the multi-towel/mitt approach, I usually only mix a gallon or two at a time. I store all my detailing stuff in the basement to keep it away from freezing/heat, and I'd like to cut down on having a stack of 5 gallon buckets down there.
I'd like to find something in the 2-2.5 gallon range that seals well to prevent spills/spoilage (I use distilled water, but every little bit helps).
I know the easy answer is to just pour whatever's left back in a gallon jug, but it'd be nice to just be able to grab and go.
What are folks using?
