I would not turn it on and let it idle or just rev the engine till it worms up. That causes even more condensation then just letting it sit there. On it's last fill up pour some Sta-bil in the tank and fill up, this will mix it well and on the drive home it will get Sta-bil in the lines as well. Disconnect your battery and put it on a trickle charger through out winter. If you want to avoid possible flat spots in your tires then buy 4 floor jack stands and get her of the ground. That's all you will need. All my mustang e-buddies do this every winter and over the years this method has proved it works for even the Canadians and Netherlands.
