Stubborn rubber having trouble with coating.
uhohitsstevo
Stubborn rubber won't absorb coating I feel like and it looks very uneven. This could just be the rubber being the way it is but the rubber on the windshield edges will absolutely not absorb any of the product and actually it seem to only absorb a little. On the window trim it ansorbed it and made it looks significantly better which I am very pleased with.
Cquartz trim and wheel coating
Windshield trim.
window edges
Bottom window trim
Top trim is windshield
What kind of vehicle is that? Some cars plastic & rubber trim is just helpless. i.e. my neighbors Honda CRv.
If it's not taking.. Well at least it's still brand new. You may find the only thing worth doing is applying something like Megs D156 Spray Wax. I know you were hoping for something alot longer lasting, but I'm not sure if there's anything you can do + you don't want to start getting aggressive trying to clean/prep new trim.
Another idea to try is maybe a tireshine. I've used tireshines before.. very carefully of course on rubber trim.
I may just use some rubbing alcohol and take it off and then use the trim restorer from mckees I have, its what I had been using before and it looked pretty good, the funny thing is some of the areas feel really nice and smooth and some of them feel like it is uneven and not taking, I don't know what the best course of action would be
Last time I checked alcohol can dry out plastic trim, you might not want to do that. Diluted APC instead.
getting the coating off with alcohol I'm pretty sure might be the only way
I see...
Those rubber bits around the windows can be such a tedious task most times. If it's in like new condition I usually treat it like the anti leather conditioner people treat leather interior and simply "clean & protect"
That's why I like spray wax on those parts.. No possible greasy mess + Protects and doesn't attract dust.
I see...
I may just end up throwing some wolfgang deep gloss paint sealant 3.0 on there and calling it a day.
If d156/ultimate quik wax is used weekly from the time you bought the car, Eldorado2k is right, it's all you need. If not, like he mentioned clean it all thoroughly with meguiars d101 APC or D108 Super Degreaser diluted 10:1. You can scrub it with either a soft bristled brush or a cheap microfiber towel. If you haven't cleaned black rubber trim before don't be alarmed by all of the black transfer. That oxidized rubber cannot be brought back to life no matter what a company claims their "dressings" or "protectants" can do to the rubber. Even Solution Finish requires the rubber to be thoroughly cleaned first. Once it's been cleaned with apc, I typically use Opti-seal, carpro reload, optimum car wax, or Meguiar's ultimate liquid wax would be the best consumer option to apply to the rubber. It makes the rubber look darker but maintains the deep rich stock look that most people strive for. The best part about using a non-staining sealant or wax is that it isn't greasy, is dry to the touch, and beads/sheets water like it does on your paint. If your rubber is still in bad shape before applying one of these products it may be necessary to use a product like optimum poli-seal which has extremely fine abrasives that will actually polish the rubber and can do an incredible job restoring the most neglected rubber or smooth plastic trim. (For textured plastic, you don't want to use any product with abrasives & I find it easier to stick with a spray sealant like reload, opti-seal, d156, etc. Best of luck to you in your rubber restoring endeavors! Update us with what you decide to use and how it worked for you!
I've found the Blackfire Trim Sealant works really well on my MK6 VW GTI trim. I wipe the application areas clean with APC and then apply the trim coating. Under normal use, I've seen about 4~6 months of protection.
I will agree not all plastic's are equal. The Blackfire product works great in my VW and the wife's Toyota. However, when applied to my daughter's Mazda, the product simply disappears no matter how heavily it's applied. For that vehicle, I simply go with a trim protectant and found Mother's Back to Black works pretty well.
The windshield trim on my '14 A4 looks identical to this. The dealer even replaced the drivers side when I took delivery and it's still terrible. Nothing to add other than I've been using 303 for the time being (Perl was a total fail, but that was expected haha)
I just put a coat of Wolfgang deep gloss paint sealant 3.0 on it. It's still black and looks good but some parts are just looking damaged. I don't wanna deal with a greasy mess.
I have used close to every wax or sealant on my rubber windows seals and black trim as long as it indicates somewhere on the label that it will not stain. I love Wolfgang DGPS and Menzerna Power lock but neither of those products say on the label they won't discolor or stain plastic or rubber. how long did you leave DGPS on the black rubber and how many times have you use DGPS to protect the same rubber pieces? I'm just really curious because I prefer it over most sealants but i never use it because I refuse to tape off trim pieces.
Polish the rubber with Essence, then coat. Do a test spot of course but it should work great.
That rubber trim that is fused to hard plastic trim usually is a high silicone content rubber to keep it highly flexible. Not surprised that many products do no absorb into it.
