SunJoe to Gilmour Adapter
Suaveat69
Sun Jow 3001 and a Giimour foamaster. I want to connect them both so I can use the foammaster on the Sun joe wand.
I tried mtm and others but can't find an adapter.
Anyplace to find an adapter?
Thanks
Just curious, why would you want to do this instead of just buying a foam cannon? I have the SPX3000 and have one that works great with it.
You could find the fittings probably at a Homedepot, Menards, or Lowes to make it work. It would just take some looking around.
This will not work so good for you. As it's 2 different products the Foam Gun and a Foamcannon. The orifice or if it's any in the foam gun it's too big to be used with a PW. So you would get less foam than from the hose if you do couple it together with the PW. Get you a foamcannon and you will be getting a great foam from the foamcannon and PW. Just a friendly advise.
/ Tony
What did you decide to do about finding an adapter?
I have both of these. It will be cheaper and easier to buy an under $20 foam cannon built for a pw
Sent from my SM-G965U using Tapatalk
Went with MATCC foam cannon. Could not find adapters. Yes the Gilmour is a high flow and as eveyone pointed out would probably not work so well.
Thanks
