Mobile detail
- May 14, 2011
- 784
Hello everyone I hope your all doing well!
So here is the deal. I have a FLEX 3401 and a PE-14-150. Im interested in getting a MF pad set up (for the DA) and want to know which is the one to get. I have read the Surbuff offers more correction but leaves a haze, and doesn't have a long Pad life expectency. The Megs system finishes better but some say that it doesn't work well (or at all) with the Flex backing plate. I will be using this mostly on Daily Drivers and I primarily use the M105 followed by the M205.I also have the D151.(just to throw another monkey wrench in the mix) Im at a total loss as to which set up to get. I'm currently using CG Hex pads which are suppossidley the same color set up as CCS. I have every color and multiples of each color. (which I do not like...rather hate...):nomore: and I have ordered the LC CCS 5.5 pads (various colors) from AG (best online store ever might I add and amazing deals):dblthumb2:. Can I use the surbuff with the 105 then follow it up the 205 on a white then apply LSP? Should I go for the megs system (MF's and D300/D301Compound/Wax) or just the MF disks and use them with the m105/205. And what size do I need to get for use with the FLEX B/P. I feel like I haven't found the right set up for polishing and keep going no where fast. Thanks in advance for any tips or advice. I have learned so much from everyone and I cant thank you enough!Feed back please
