AL417
- Oct 15, 2006
- 1,442
Mini Review:
Surf City Garage Road Trip Grime Destroyer
I had a chance to put this product to the test this past Saturday. I met a guy at a local festival who had just driven his car through fresh road tar/oil four days earlier. Just my luck the car is white. I really thought I had my work cut out for me and that this was going to be a very time consuming detail. All in all I was able to cut through all of the tar/oil in about an hour. The pics don’t do it justice but let’s just say that Surf City Garage Road Trip Grime Destroyer and a Pinnacle Safe Scrub Bug and Tar Pad worked wonders together. The Grime Destroyer did its stuff very well; I used the Pinnacle Pad to spread the Grime Destroyer across all of the panels because the product is very thick and almost gel as it is sprayed. It did take some elbow grease to remove the tar but it wasn’t too bad. I was happy with the results and how quickly the caked on tar mess came off. Now on to the Show N’ Shine….
The Detail
Exterior Only
Rinsed down with plain water
Attacked the tar/oil with Surf City Garage Road Trip Grime Destroyer
Spread the Grime Destroyer with the Pinnacle Pad
Let this dwell for 10-15 minutes per section
Because of the severity of the tar/oil I used the Pinnacle Pad to scrub off the tar
Rinsed the vehicle again and the washed with DP Xtreme Shampoo and Foam Gun
Ultimate Guzzler for dry down
DP Wheel Gel Cleaner and black ShMITT
Polished with XMT360 on the UDM with CCS Orange Pad
Pinnacle Signature Series II
DP Krystal Vision on windows
DG #265 on tires
Before
In Process/Dwell Time
The Detail
Exterior Only
DG #265 on tires
Before
