What’s your problem with IPA? It certainly is the most economical, any other dedicated wax remover like Carpro eraser is going to cost you more money.
Im currently using megs m122. Liking it, no complaints...other than the slight vinegar smell lolBesides ipa. What is another economical wax remove. One used before a ceramic coating application
Thanks
A good watch.
That was interesting
Paul A mentioned that concoction in a separate thread
I’m not doing coatings, I just want to make sure every bit of filler or lubricant or residue is removed after correcting so I’m seeing the true “what you see is what you get” so I guess any name brand prep wipe will do what I need
Yvan’s opinion regarding IPA or alcohol as essentially worthless is interesting, especially considering how many top tier paint correction and protection pros use itn
I know his training is firmly rooted in the chemistry aspect of detailing products after all his years with OPT
To sum it up I think I know less now than I did when this thread started
Black Fire paint prep has worked well for me the two times I use it. It goes on sale for 30-40% off sometimes on BF or AG website.
Got a gallon for for $36.
See alot of people using and liking Kleen Strip Prep All. I have not used it.
Acetone and windex. Sounds like a inexpensive option. I’m guessing this is ok on the paint. The guy seemed to know what he was talking about
I use it. I also use OTC Optimum paint prep. Works fine.Acetone and windex. Sounds like a inexpensive option. I’m guessing this is ok on the paint. The guy seemed to know what he was talking about
