I have a very weird issue at the moment, doing a correction polish on my car with messed up sides (previous owner probably used contact carwash or rubbing sand on the panels..)
Keep in mind I am a n00b at this;
Using a Griots G9 DA, with chemical guys Orange (medium cutting) pad, and a combination of sonax cut & finish and 04/06 depending on affected area. The cut and finish provided the best result on my door test panel. Of course i still have some deep scratches but i would say 80% is gone and i'm good with it.
When my section is done (about 5 section passes), I wipe very gently with a CLEAN microfiber. Product is sort of "greasy" when i'm done so it's kind of a pain to remove correctly ( working indoors in about 55-60F with around 60% humidity)
I observe my work, well satisfied of the result (use of different light sources in every possible angle), then clean my pad (shower towel, brush & compressed air), then proceed to next section. -btw big thanks to Mr. Phillips and everyone else for the great info, tips. techniques provided on this site!!
Now, maybe two days later, keep in mind the car is inside the garage, I'm the only one with access, no pets, and i am careful moving around it, i see this;
View attachment 77030View attachment 77031
To make those marks/holograms appear, i need to shine my light in a very wide angle (maybe 150deg?). They were not there when i wiped down and inspected.
Now, what would cause this issue? Looks good one day, not so much one or two later?
I did a test this morning on this exact panel and will keep you updated in the next two days to see if it worked; Chemical guys Green heavy polishing pad with sonax NP 03-06. Did 4 section passes, wiped down extra gently, even did an IPA spray, looked perfect before i left for work. Will check it tonight and tomorrow am.
Any info will be gladly appreciated, my "it;s going to be a fun two days with a few beers" is turning into a nightmare...
Thanks!
Thanks!
