the reason why you wouldn't want to use an absorber is because it has no nap so if there's any contamination on it, you will potentially risk scratching the paint when wiping. use a quality mf towel (which has a deep pile/nap), you can't go wrong with it...
p.s. if you blot dry with an absorber and frequently monitor it as you dry, then it shouldn't be much of a problem...
No rinse/rinse-less car-washes:I've read from different users that using Synthetic Chamois with onr can scratch the paint...
As above...if you have to use a synthetic chamois blot the majority then wipe it with a nice MF towel.
