kevincwelch
- May 12, 2013
- 2,686
I'm not seeing anything on AG or CarPro's website about being unsafe for coatings. Heard Tarminator might be, but is Tar-X safe on coatings?
No, I haven't tried anything yet. I bought Tar-X for the purpose of removing tar. I finally have tar on my car, and I'd like to use it.
If it's unsafe, I'll just say "bummer" and try an APC first.
But, I'm hoping my TarX isn't just a paperweight now.
Thanks, Bob.
I will probably try a small spot near the trim and then test for hydrophobicity afterwards, which is the best proxy I can think of that the coating still exists. If not, I have some C1 laying around... All out of 22PLE, which is the primary coating now.
Thank you for weighing in, Avi.
I tried the Tar-X on my car. The tar problem was worse than I initially thought because my car is dark blue -- I just wasn't seeing how much tar splatter there was given the regular dirt until I washed it.
The coatings on my car were 22PLE topped with Gyeon Booster.
At the very most, I can say that after application of Tar-X there was at least some coating remaining. I cannot tell how much, but the panels clearly beaded and there was decent water sheeting.
I ran out of Tar-X at one point and had to resort to using Tri-X. This definitely did something to the coatings, as there was very little beading and poor sheeting after it was used to get rid of the tar. I am reminded of a warning on Gtechniq's website that says Iron-X may be harmful to Gtechniq coatings. This very unscientific test of Tri-X would suggest that it may jeopardize the coatings as well, and I suspect it is the Iron-X component.
Anyway, I had to wash, Eraser and apply Hydro2 to the areas where I applied Tri-X -- basically the whole back of my car. I put Hydro2 on the areas where I applied Tar-X as well, but I'm not sure if it really added anything.
This sort of sucks because I really don't have any time to redo any definitive coating until next summer. I have some C1 left over, and I suppose I could apply that, but coatings take time to get right -- prep and all. Therefore, I'm hoping that Hydro2 every month or so will be sufficient.
I could also use Hydrofoam or Gyeon Bathe+, but the time I will have left to actually wash my car before the temps drop is about 1-2 months. Seems like a good problem for Hydrofoam and Hydro2 to solve.
I could put a layer or two of Powerlock or WG 3.0. That should also get me through the winter.
Any other suggestions?
