Rod73
Member
- Sep 20, 2014
- 667
- 1
From someone who has moved from the Porter Cable 7424xp to the Rupes Duetto is there a real difference in how I use it in terms of speed of movement and section passes. I know the longer throw of the Rupes polishers speed up progress. Considering the point of emphasis with the Porter Cable was moving it slow I wasn't sure if I should maintain that same pace or pick it up a certain amount? I'm also accustomed to an average of the 4 to 7 correction/medium cut passes and maybe slightly more for SF4500 ultra fine cut.. I wonder if I should expect that same model when I polish?
