temperature ranges used for ceramic coatings
sorj
What temperature ranges are you applying ceramic coatings? Are you mobile or using a dedicated shop, and where are you located (generically)?
I am still trying to decide whether to be mobile, or rent space for a dedicated shop, and this is one of the factors.
Gyeon states to apply their coatings: 59F to 77F, and I have not found any other brand's temperature specs.
* 59F to 77F would be very limiting in northeast Ohio as a mobile detailer
* That temperature range also causes issues as a shop too. A minimum of 59F should be easy enough with heat, but an upper limit of 77F would require air conditioning, and I am not finding warehouse space for lease that is air conditioned.
Thanks in advance!
