Waxing by hand is fine with this Wolfgang Polishin’ Pal is an ergonomically shaped urethane handle that holds specially designed foam pads using hooks & loops. or this Griots Garage 4” Hand Waxing and Correcting Pad Kit and cleaner waxes are fine however any correction to remove swirls you are going to wish for one of these Griots Garage 6 Inch Random Orbital Polisher FREE BONUS!. I can't even imagine trying to go beyond waxes and sealants without some type of quality machine if your budget will allow. I started by hand and found the results to be like spitting into the wind.
For a AIO on nice pretty new car a couple years old ,is a ironx type product enough or should I clay also??Note: It's really easy to micro-mar soft paint by hand with microfiber applicators. They're often made of cheap microfiber. It is crucial to make sure you've got even pressure across the face of the pad (i.e. watch the fingertips!).
Along that same line... I find claying absolutely necessary before hand applying anything. If you don't clay-- Little contamination bits can become dislodged and embedded in applicator pads. Combined with concentrated pressure of the fingers (or worse, finger tips), these bits can easily cause marring.
For these reasons, I stick with foam (unless I'm intentionally working on RIDS). Even then, I'd try foam first.
Is IronX enough? I'd say no. in my opinion claying is more important than ironX.For a AIO on nice pretty new car a couple years old ,is a ironx type product enough or should I clay also??
Removal of polish and wax is done with microfiber towel??
