PA DETAILER
- Mar 5, 2011
- 6,027
- 271
Finally moved my stuff this morning to a heated portion of the garage. Going to get below freezing the next couple of nights.
Winter sucks
What part of Pa. you in PD ? I'm in Northampton County, so yes all the supplies got to get in the warm..and don't forget the pressure washers..
Winter sucks already and not even technically here yet..
I’m trying this on my pressure washer this winter and storing it in the new shed
I moved as much as I could out of the garage and into the shed so both cars will get to live in a heated garage for the first time ever
Wait a minute--when you said you only had a carport--you really had a garage but it had too much stuff in it so you kept the car outside? In Alaska?? That sounds like something that would happen to me, I have my cars in the garage but I'm running out of room in the house for me.
That Sta-Bil stuff works good Mikey. Just be sure to empty out the pump the best you can before you use it.
Snazzy Snow Blower you have there........![]()
I've used the expensive pump protectant/anti-freeze from Briggs & Stratton for some time. Every year when I do it I wonder to myself if it isn't just snake oil. If you drained the pw in the fall what is there to freeze up & cause damage?
Fanks Paulie, I have a set of tire chains coming from Ariens, it was having a hard time with some of the hard wind packed drifts we have been getting and I am hoping they help
Isn't some of the function anti-rust? Even if there isn't enough water for freeze damage, it's still going to be wet in there to rust everything up.
