DaC
- Aug 11, 2011
- 855
So guys, today I first used the Nanoskin Autoscrub Medium Grade 6" pad...... and I must say I'm pretty impressed, it really didn't hazed the paint on a very soft solid black (although it was so full of swirls that it was hard to tell).
I used the all mighty Ultima Waterless Wash Plus, which is by itself a truly amazing product, as quick detailer and the result was great.
While using this product you do have to use a lot of lube, or else you run into the risk of leaving some rubber trace, which most of it is easily wiped off with a damp towel.
You don't need to work a small section at a time, just make sure the QD you have already sprayed won't dry or run before you can reach the working area.
Pros
- Easy to use
- Much Faster than a clabay given the same cleaning level is achieved
- The Medium grade, at least, will remove contaminants a lot better than a claybar given the same amount of time.
- The paint surface gets so smooth that nothing will stand over it without wanting to slip away. It's almost like a fresh waxed surface.
- According to the manufacture you should expect a much higher useful life than a claybar, I personally didn't saw any wear after this 1st time use.
- It's easier on your body than claying.
Cons
- None that I can think of
Bottom line
- The 6" pad is a little too big to fit some spaces, but there's a smaller one.... Although of this I really don't think it's much of issue... just grab a piece of clay to finish on these vary hard to reach or small areas.
- Price ? Well, if it lasts as much as the manufacture says, it's far from being a con
To sum up
I really loved to work with it
Here's the video from the bag test.
[video=youtube_share;YEYXdo-hp5U"]The bag test after NanoSkin Autoscrub - Medium Grade 6" + UWW+ - YouTube[/video]
Pros
- Easy to use
Cons
Bottom line
To sum up
