atgonzales
- Oct 5, 2013
- 744
Hello All
Bobby at AG was kind enough to send me the following to review:
I used the full product line on 2014 Porsche Cayman R, the client requested wax only, no sealant or coatings on the paintwork as it will given a full correction in the Spring of 2018.
Wheels first: here is the shot of the dirty wheel:
The wheel cleaner to my surprise did have the chemical make up to turn brake dust purple and it did have that all familiar chemical ordor we love/hate so well and the product tried to mask the smell with a hint of grape scent. I would give this B- because this product would work very good on a well maintained wheel.
After shot:
Next up is the shampoo, which smelled like grape bubblegum, the directions stated use a cap full per gallon, so what is cap full from the black cap on the bottle? I poured water in the cap and it measured .5 of an ounce, so in my bucket which had 4 gallons of water I used 2 ounces and in my foam cannon bottle 2.5 ounces. The product is rather thick and made a little difficult to get the product out of my measuring cup. I had to actually use my finger to remove the product.
Bucket foam
Car foamed
Shampoo gets an B+ as the product is too thick and directions did not state ounce mearurents and if I used the cap from the bottle it would have made a mess of the bottle after use
The wax, it had no order at all, easy to use, spread thin, a little goes a long way
Here is the shot of open jar, a little disappointed on appearance.
Tool used and the 3” pad fit in the jar very well and forgot what a pleasure it is to use the Griots mini
The wax gets a B+ as the product should have been smooth/level when you open the jar
The glass cleaner was very nice to use no streaks or hazing, I spayed the product on a white glass towel and turned it over to buff the rest off, the product smelled like wintergreen
I’m giving this A, it did what it is meant to do
Metal polish had no fragrance and was white in apperance
Here is what it took off on the exhaust
This gets a solid A
Tire dressing very nice product not to thick or runny, I used a Carrand tire brush and applied the product direct on the brush
The product once applied gives the tires a very shiny black apperance but my OCD got to me and used a papertowel to knock the shine down in fear of tire sling and because I know what my client likes his tires to look like
Here are the glory shots:
Final thoughts and observations:
The red plug....in the shampoo, metal polish, wheel cleaner are a pain to remove, I had to use a thin head screwdriver to remove them and while removing them I had remain cautious to not spill product
Look at the first pictures, the labeling of the product is not consistent, “Detailing Garage” is in an oval and not in an oval. The apperance of the wax in the open jar. The small things, I know... Did the products perform as they should have YES, will my clients ever see the products probably not
I hope you enjoyed the review
All the best
After shot:
Bucket foam
Car foamed
This gets a solid A
All the best
