Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
The Compression Washer
I wrote an article about Compression Washers explaining how important it is to the function of DA Polishers here,
Don't use your polisher without it!
There were some further follow-up questions about compression washers so here's some more pictures and information to make sure everyone's clear on what the compression washer is, where it goes and why it's important.
The common Compression Washer used with popular DA Polishers is about the size of a U.S. Quarter.
One side of the compression washer is going to seat against the free floating spindle seen in the picture below.
The other side of the compression washer will seat against the small steel attachment plate on the back of a backing plate.
It would look like this without the backing plate in the way...
Normally you would slide the compression washer over the threaded portion of the backing plate and then align this to the spindle on the polisher and tighten together.
Nylon Compression Washer
Here you can see where after tightening the compression washer has an imprint from where it was crushed during tightening.
Fiber Compression Washer
Do's and Don'ts
Compression washers do wear out with use, that is if you remove and replace backing plates often you're going to wear your compression washer out.
Autogeek carries replacements...
Lake Country Compression Washers 5-Pack
Do's and Don'ts
- Do use a compression washer between the backing plate and the spindle.
- Don't use a steel washer if you lose the compression washer.
