Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
The least invasive method to dry your car - Patting instead of wiping off rinse water
Patting rinse water off a car...
Years and years ago I learned from a Porsche owner, (black paint), a method for drying your car by patting the rinse water off the paint instead of wiping the rinse water off the paint when using a drying chamois or drying towel.
The idea being that laying a clean drying towel onto a wet car after rinsing and gently patting the water off instead of rubbing the drying towel against the paint was safer for the paint as you reduced the risk and potential for any marring caused by the pressure of the drying towel being wiped or rubbed against the paint.
Made sense to me. Especially if you have a brand new car, a brand new paint job or if you have spent hours polishing the paint to perfection.
The big picture being that IF a person wanted to do everything they could do to be as careful as possible so as to not re-instill swirls and scratches into otherwise flawless paint then patting dry was a safer option than wiping dry. This makes sense because by their very nature, modern clearcoats are scratch-sensitive. While modern clearcoats tend to be harder than old fashioned single stage paints, they still scratch very easily. And because they tend to be hard, removing swirls and scratches can be time consuming. So little tips or techniques like patting rinse water off your car makes sense and it really doesn't take that much more time but it does tend to require a few extra towels to do it quickly.
Here at Autogeek we offer a microfiber waffle weave drying towel the Guzzler HD Waffle Weave Drying Towel. The Guzzler HD is unique in that it has a 1/4" foam core. This makes it very good for the patting technique for drying your car as the soft microfiber weave material absorbs water into itself and then into the foam core. The foam core makes the towel a tick more stout (while remaining very soft), and this little bit more stoutness works well for the water patting technique.
Patting water off your car's finish only takes a little more time than wiping the water off. It does work best by having a few extra towels on hand for when it's time to dry the car. It has the same soft microfiber waffle weave outer material but also includes a 1/4" water absorbing foam inter-core. So you place this towel flat on a surface, allow the water to migrate into the microfiber and then into the foam inter-core and presto... the water is gone and the surface is dry without wiping. For vertical sides, gently press the Guzzler against the paint and it will remove the water instantly.
If you prize the finish on your car, consider using the water patting technique to remove rinse water.
On Autogeek.com
Single Guzzler HD Waffle Weave Drying Towel - 16 x 24 inches.
6-Pack of Cobra Guzzler HD Waffle Weave Drying Towels - 16 x 24 inches
On Autogeek.com
