The New SSR1
smokin' mark
Has anyone used this? I tried it and man it works great...much better than the previous SSR1. Maybe it's just me but it seems you have to use a lot more product than before.
Mark
the new one is yellow thwe older oen is pink. go figure it out.
Sorry..."new" to me means within this calendar year :) It really does a great job, it seems you just have to use it liberally.
Pockets, it's probably me not the product. I don't do this for a living or anything, just "on the side" for extra cash. I worked it with a Cyclo and A/G double sided green pads. No question it is superior to the previous SSR1 in results. I would put it on par with WGFG at half the cost. Old vs. New SSR1 are definitely different in application though. The former produced a ton of sling if you used too much...but very little dust regardless. The current produces almost no sling regardless, but a ton of dust if you don't use enough.
I use the "quick-connect" system. The pads have two sides. You know, you use one side of the pads then flip them over. I assume they are clean. I use the small packets of pad-cleaner that AG sells. They seem to do a great job.
