Desertnate
- Aug 5, 2013
- 6,186
- 233
Simple, regular-strength wheel cleaners don't get much attention these days, and I think the Griots Wheel Cleaner is really an overlooked gem. I've been using the Griots for a couple years now and I'm on my third gallon jug. I like it that much.
In addition to doing a quick review of this great wheel cleaner, I thought I'd show how well a regular wheel cleaner will work on some seriously nasty wheels. There is a time and place for products like Meguiars Wheel Brightener or Brown Royal, but in the spirit of using the least aggressive approach first I'd encourage everyone to try a regular strength cleaner first. You might be surprised by the level of cleaning power.
Now on with the wheels:
A few weeks ago I delaminated the outer tread blocks on one of my front tires following an autocross event. For several years, I ran events on my regular wheel/tire sets, but soon realized I was tearing through tires faster than I should and by running a staggered wheel set on normal summer tires I was giving up several seconds to my competitors. So I went in search of a dedicated set of wheels and tires in a square set up. This lead me to stumble across a screaming deal on a used set in a city not far away. While the wheels and the sticky tires were exactly what I needed, they were a bit, ummm....grimy. I understand these are race wheels and you aren't gong to show them the same love as a set you drive on daily, but these were so bad you couldn't touch them without turning your hands black with brake dust!
Here is what they looked like after I brought them home. The previous owner wiped down the faces, but hadn't touched the barrels...maybe ever.
After giving the barrels a good spray down with the Griots Wheel Cleaner, I found the 50/50 to look pretty amazing. The wheel cleaned up pretty effortlessly.
The wheels were then finished off front and back, and here are the results. I bet they haven't looked this good since the owner pulled them out of the box!
I will freely admit there were a few globs of rubber and tar from the track which the wheel cleaner didn't remove, but I wouldn't expect it to. A little Stoner's Tarminator and those were easily removed as well. Also, two of the wheels were oddly dirtier than the others. The dust looked no different than the one I pictured, but after the first cleaning there were areas on the barrels that simply wouldn't come off. I spot cleaned them with a bottle of Meguiars Hot Wheels Chrome Cleaner after Eldorado2K letting me know it's the consumer form of Wheel Brightener. That stuff is SERIOUSLY strong, and knocked out those trouble spots like they were nothing. No way I'd use that stuff on a regular basis, but it does serve a purpose!
