SYMAWD
- Feb 10, 2013
- 1,667
So I'll start with Wheel Brightener is hazardous to your health and should be used with proper PPE. It is also not safe for all wheel, brake, and suspension components. However, say you are doing production washing or detailing, it can be useful.
Here are some nasty BMW X5 wheels:
After spraying on wheel brightener and rinsing with a pressure washer:
Sure it is not 100% perfect and the barrel would require agitation as you can't really get a stream of water back there and heavily embedded brake dust will not be completely removed.
To recap, exercise caution when using this product and I am not necessarily recommending you use it. I am just sharing the results and would personally recommend that you normally use something safer for both you and the car, but wheel brightener can be useful if you need dirty wheels cleaned quickly.
