The Protector
BILLY D
Hello, I am from Puerto Rico, Greetings to all. This is my first post, my Black Jeep JK has The PROTECTOR from ECP and I'm not sure if if they polished the paint before applying the protective layer.My paint has a lot of scratches and swirl mark that does not come with the cleaner wax they recommend . Any suggestions. would appreciate your support.
You will need to remove the coating before you can polish out the defects in the paint. Then you will have to reapply the coating, sealant, or wax.
Thanks for your reply. Any idea how to remove this treatment .
If it's a 'Coating':
It'll have to be abraded-off with an abrasive compound/polish
Why do you want to remove it?
It had to cost a pretty penny.
I found the below information to be quite interesting.
____________________________________________________________________________________________________
Word Mark: THE PROTECTOR
Status/Status Date:
REGISTERED AND RENEWED 8/17/2007
Serial Number: 73221319
Filing Date: 6/27/1979
Registration Number: 1449099
Registration Date: 7/28/1987
Goods and Services:
Vehicle Exterior Paint Sealant; Vehicle Soundproofing Compositions;
and Vehicle Interior Fabric Protective Coatings:
All Sold Exclusively to New Car and Vehicle Dealerships
Mark Description: NOT AVAILABLE
Type Of Mark: TradeMark
Published For Opposition Date: 8/18/1981
Last Applicant/Owner: ECP Incorporated, WOODRIDGE 60517
Classification Information
International Class Code(s): 001
US Class Code(s): 006
Primary Class: Chemicals used in:
Industry, science, photography, agriculture, horticulture, forestry;
Unprocessed artificial resins; unprocessed plastics; Manures;
Fire extinguishing compositions; tempering and soldering preparations;
Chemical substances for:
Preserving foodstuffs; tanning substances; adhesives used in industry.
Class(es) Status: Active
First Use Anywhere: 5/21/1979
First Use In Commerce: 6/8/1979
Thanks for the support and suggestions, First I'll be trying to fix the paint with a PC and MF pad,swirl remover and M205. I hope this makes the finish look better
