The white foam pad that comes with a Porter Cable Polisher
For years I've seen people post questions about the white foam buffing pad that comes with a Porter Cable DA Polisher and I've also seen some confusion over whether or not a person needs to order a dedicated backing plate with the tool?
So here's the skinny, the white pad in the box,
  • Is a Polishing Pad, not a cutting pad or a finishing pad
  • Has a fixed backing plate that is glued to the foam, it cannot be detached and used with other pads
  • Measures approximately 6" in diameter and is 1.5" thick
Porter Cable 7424XP brand new in the box...
Here's the included white foam polishing pad...
Here's the glued-on plastic backing plate...
The pad comes with a compression washer, if you choose to use the pad, be sure to include the compression washer
Here's a 5.5" Lake Country Flat pad side by side with the factory pad to show how thick the factory PC pad is compared to a 7/8" thin pad.
Here's the 5.5" LC Flat Pad with a Lake Country 5" backing plate attached
Here's another shot to show the differences...
Make sure the compression washer is installed on the threaded stud before attaching to the spindle of the Porter Cable DA Polisher
The pad is approximately 6" in diameter...
The factory included pad is 1 1/2" thick...
Question: Can I use the included foam polishing pad with my Porter Cable 7424XP
Answer: Yes but sooner or later you're going to need more pads and in order to use other pads you're also going to need a dedicated backing plate.
Question: What can the factory included foam pad be used for?
Answer: The foam used for this pad is a firm polishing pad, it's not as aggressive as a foam cutting pad or as gentle as a soft finishing pad. Polishing pads can be used to remove medium to shallow swirls and scratches, oxidation and water spots They can also be used to apply a one-step cleaner wax. Some people will take the factory included foam pad and place a clean, dry microfiber bonnet over it and use to remove dried wax.
Question: Can I wash the factory included pad and use it again?
Answer: Yes, kind of by hand in a sink or in a bucket of water but because the backing plate is glued on you have to be careful you don't loosen the adhesion between the plastic backing plate and the foam which could cause problems should it detach while you're buffing. The glued on backing plate will also make it harder to wash and rinse the pad by hand.
Big Picture - Get a dedicated backing plate and a collection of buffing pads
Most people discard the pad and when purchasing the Porter Cable 7424XP they go ahead and purchase a dedicated backing plate and a supply of buffing pads and by doing this they can instantly get to work buffing out their favorite car.
If you're going to order a Porter Cable 7424XP then start out the right way and invest in a backing plate and a collection of foam pads. If you're going to be removing swirls, scratches, water spots and oxidation it's a good idea to get a variety of pads so you can match the pad to the job you're doing. A good starter collection would include foam cutting pads, polishing pads and waxing or finishing pads.
Autogeek offers a variety of pre-configured kits on the Autogeek Store website or you can call Customer Care and they can help you build a tailor made kit specific to your polishing needs.
On Autogeek.net
Porter Cable 7424XP
From left to right...
Lake Country 5" DA Backing Plate
Meguiars W67DA G110 DA Polisher 5 inch Backing Plate
The Black Dual Action 5 Inch HD Backing Plate
Lake Country 5.5" Foam Buffing Pads
Lake Country 5.5" Flat Pads
Lake Country 5.5" CCS Pads
Lake Country Hydro-Tech Low Profile 5 1/2 x 7/8 Inch Foam Pads
Video: Mark your backing plate to make it easy to see pad rotation
Questions? Call 1-800-869-3011
Resources
The Art of Detailing how-to book includes step by step directions on how to use a DA Polisher to remove swirls, scratches, water spots and oxidation to create a show car finish.
Paperback
E-book
(Displayed on iPad - iPad not included)
Mike Phillips' The Art Of Detailing Audio Book
Mike Phillips' Principles of Machine Polishing
Brand new DVD's on how to detail your car, all include using the Porter Cable 7424XP
How to Properly Use the Porter Cable 7424XP Dual Action Polisher
Learn how to polish and protect your vehicle with the user-friendly Porter Cable 7424XP Dual Action Polisher. Mike Phillips walks you through the essential steps to maintaining a smooth, glossy finish with this machine. The techniques you learn are transferable to many other 6 inch dual action polishers.
In this DVD, Mike discusses pad selection, polish application, how to make a section pass, and how to apply wax with your PC, plus many more tips developed through Mike's years of experience detailing cars.
Mike Phillips is our Director of Training at Autogeek. He teaches machine polishing classes here in the Autogeek Show Car Garage several times a year, where detailers learn the techniques you'll see in this video. Now you can bring Mike into your own garage with this DVD, "How to Properly Use the Porter Cable 7424XP Dual Action Polisher."
Pinnacle Complete Car Care System Instructional How-to DVD
The Pinnacle Natural Brilliance How-To DVD has been updated with the latest techniques. Mike Phillips and special guest Matt Steele demonstrate how to use Pinnacle products to create a sizzling shine.
Wolfgang Concours Series Instructional How-To DVD
The Wolfgang Concours Series Instructional DVD, hosted by Mike Phillips and Bruno Massel, walks you through the products and processes that will give your vehicle a head-turning gloss and unbeatable protection. The DVD demonstrates every step of the detailing process in full color and sound. You can see exactly what products are used with what tools.
Pinnacle XMT Series Instructional DVD
Learn how to maintain a like-new finish with the XMT Series Instructional DVD hosted by Mike Phillips and Matt Steele. In this video, Mike and Matt demonstrate how XMT products clean, polish, and protect your vehicle's surfaces. You'll learn proper application techniques, the correct sequence of product use, and what tools to use.
:xyxthumbs:
Great info Mike. Always wondered what that white pad was good for. The black washer that comes with the backing plates in the pictures above do you leave that on? I have always left them on...Is that the same as the compression washer you are talking about?
Great question and the answer is "yes"
The Compression Washer
Normally you would slide the compression washer over the threaded portion of the backing plate and then align this to the spindle on the polisher and tighten together.
I thought it was used for removing wax with a microfiber bonnet on top of it to hahhaa
Yes, it sure can be used that way.
I've cut the pad in 2 parts to make some good tire gel pads.. Works great.
Yes, that is a popular use for the box, stock white pad that comes with the tool. I though I mentioned it in the thread but apparently left that little tidbit out. I have an article on that technique here,
How to use a microfiber bonnet to remove dried wax by machine
And show the technique in this video,
Video: How to remove shallow RIDS and how to machine apply both a paint sealant and a finishing wax
And there you go...
:xyxthumbs:
It works pretty well for cleaning a stainless steel sink with metal polish. That's the only use I ever found for it.
Hello. New guy, old thread, Question.
Would it be of any use for polishing my chrome bumpers on my truck? They're not pitted, only dirty. I was wondering if I could just use that pad as the stand alone, only use pad, for a polishing/cleaner/wax for my chromed bumpers? I'm buying other pads for the rest of the truck, would a different type pad be better served for this?
All I can say is, give it shot. Doubt you'd be doing any damage to the bumper.
Bill
I do not like taking off my backing plate because the washer falls off so easily.
And It seems to be so crucial for it to stay on.
Can't I just use a regular 6" pad on my flexible backing plate and a attach a bonnet over it?
I'd imagine the answer is yes, and that probably the important key issues will be that the Bonnet fits snugly on the pad, that if it's loose that will create problems that the Bonnet won't work properly for one (will slip), and it could have a tendency to want to come off the backing pad while in use.
The degree of snugness, and maintaining snugness will then depend upon the size of the Bonnet, and also the thickness, and firmness of the backing pad.
Mark
I love these pads for polishing diamond plate and metals. I have acquired a bunch of them and will miss them for metal polishing after they are all gone.
I decided to use mine to polish some scratches out of my hood scoop and then washed it in the sink, and had the great idea of spinning it dry with the PC, and it ripped apart. :/ <<<Newb
Good thread Mike! You never stop learning in a forum like this and with this qualified people.
