Well, got my bottle in today, and the seller even included a nice size sample of 85RE5 for me to try too.
Here's what I did:
I did only the trunk, since it's all I had time for.
1. Washed the entire car
2. Cleaned the trunk with CM (no fallout, so I didn't clay)
3. Used the XMT3 for the first time. Used a light cut orange Edge 200 pad at 5 to 6 on the 7336, and it worked well. Got out almost all the swirls/scratches except the deepest ones (they aren't down to the metal, fyi). Went slowly, and worked it in about 4-5 minutes per roughly 2x2 section on the trunk.
4. Used the PO85RD with the blue Edge 2000 pad at about 1.5 on the 7336. Great stuff, left the surface very smooth and glossy looking. Again, worked it in for about the same amount of time. It appears to be everything I've read about it, and I'm very satisfied.
5. One coat of SG, WO/WO
6. One coat of NB
7. One more coat of CM for good measure.
Now, here's my questions:
1. Had some light micromarring, so should I have gone down to XMT1 with the blue pad or orange pad before I did the PO85RD?
2. For the deeper scratches, should I now go one pad more aggressive with the XMT3? If not, then what? (I have both XMT3 and XMT1)
3. Should I have used AIO somewhere in there?
4. When I did the PO85RD at speed 1.5, the pad doesn't seem to spin that much. Am I applying too much pressure? The bottle says to use "med." pressure. Should I have used the white pad instead of the blue pad?
Thanks for everyones continued help...my head is spinning from all the combinations lol
Here's what I did:
6. One coat of NB
