Greetings,
I'm more of a weekend warrior as per detailing terms here, our company imports vehicles and they often need to be thorougly washed and detailed. Most of them are Mercedes Benz models with black paint, usually Obsidian Black 197U. I'll briefly describe my method and equipment below.
Firstly the wheels are decontaminated and thorougly washed with conjuction to wheel arches, after that the engine bay is degreased and dressed with Meguiar's Hyper Dressing, boot crevices and all panel gaps are cleaned. After that the car is rinsed, decontaminated and hand washed with microfiber mitt and two-bucket method. The vehicle is then driven into garage and dried with compressed air for the gaps and towels for all the other areas. Then commences the claying process after which I usually IPA wipe the whole vehicle, tape it and then starts the most time-consuming process which seems to take too long.
Pads and polishes used:
Compounding pads: Meguiar's microfiber pads and kamikaze wool pad
Compounds: Kamikaze cutting compound, Meguiars compound, Menzerna 400.
Polishing/finishing pads: Rupes yellow pad and Kamikaze polishing and finishing pads.
Polishing/finishing liquids: Sonax perfect finish and Kamikaze products.
At start of the polishing process I check the whole car with a paint depth gauge and have a look-over with Scangrip hand held light to see if there are any problematic spots or previously painted panels.
Polishers: Rupes iBrid nano for all edges and smaller areas, Rupes 75E for mid-sized sections and spots which need precision, LHR15 for bigger areas.
Usually when polishing I've done 2-3 both horizontally and vertically so in total 4-6 passes. The microfiber pads have to be blown clean after each time I stop the polisher after one section, they get clogged up especially on the iBrid. Speed used mostly is 4-5 for compounding and 3,5-4 for finishing.
Most often I've tried to get all the scratches out and strived for perfection but it seems to take 3-5 tries with compound. Last car I did was a Mercedes Benz CL coupe from early 2000's, it took me in total about 50-70 hours to both compound and finish which seems to be quite a lot after reading that people here can get their car polished in 3-5 hours - am I doing something wrong or should I invest in more pads/compounds for different paint types? Which ones would be suggested for black Mercedes paint since that's the usual culprit for me?
The results I'm happy with, after coating the vehicle with Miyabi and ISM it looked fantastic but most cars take me 30-80 hours to polish to perfection and it seems like it shouldn't take that long and there may be a flaw in my equipment or technique. Washing, claying, interior etc in total usually takes me 10 hours including leather care/coating and so on but compounding/finishing as close to perfection as my limited skillset can provide seems to be taking ages.
I will include a few pictures of the previous state and results below so the paint state that I'm usually working with should be clear.
I'm very happy with the finished results and love looking at the car but should a polishing process take that long when the vehicle is in such condition as stated above? It seems like a "no" answer I predict and I'd very happily accept suggestions.
Thanks in advance!
Thanks in advance!
