Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
Tips on how to jewel paint using a rotary buffer
Before starting, we went over a few tips and techniques for how to jewel paint when using a rotary buffer.
Less than the weight of the machine
This is showing that we're actually using a little bit less than the weight of the machine for the last few passes for this section. The idea being that polishing paint is an art form, not a grinding process. As the pad becomes wet with product it will easily compress with just the weight of the tool. For your last few passes you want light pressure via the pad contact, now heavy pressure and to get light contact you need to watch and prevent pad compression.
Lake Country Gold Jeweling Pads
