Setec Astronomy
- Aug 31, 2010
- 17,092
- 1,397
Put in a moisture trap or filter. Drain your tank every few days, preferably every night.
I do my work at my full time job they have multiple industrial size tanks lol I'm not going to even try and figure out which one goes where or tamper with them in anyway.
Have you talked to someone there? It may be that part of the air equipment is malfunctioning causing the large amount of water you have in the air. If that's "normal" for your place, some sort of inexpensive separator as Status suggested may help. Water can be very damaging in an air system to both the generation side and the end-use equipment, so you may get some brownie points either way.
As far as tampering, if they let you use a bay then you are already using their equipment, a cheap filter/separator would just be installed where the air line comes from the wall, and then the hose would screw into it. They have a number of options at Harbor Freight for less than $10.
