Tire Shine that won't yellow
Stumann
I have a 78 Trans-Am that has BFGoodrich Radial TA RWL tires. I've tried several brands of tire shine and so far all of them will yellow my RWL's within a few days. Is there a product out there that won't yellow?
I’ve never had Meguiars M40 Vinyl &
Rubber Cleaner/Conditioner
cause
any yellow-ing to the RWLs on tires.
What have you tried?
I have had great success with Mckees37 tire and rubber rejuvinator followed by their tire gel. If you want more longevity go with their tire coating. Mckees 37 is working on a Spray Tire Shine Soi2 enhanced. I have a sample of it and it lasts about 3 weeks. I haven't reapplied anything in over a month and have zero browning or yellowing.
The key is to clean the tire extremely well then apply your tire shine product.
Sent from my SM-G955U using Tapatalk
I'd bet you're not get the tires clean before you apply the "tire shine", you're most likely picking up dirt on the applicator and when you go over the white letters it looks yellow.
How old are the tires? If they're older than about 5 years or so, I've seen this problem a few times.
If you don'y find exactly what you are looking for, try this.
After thoroughly cleaning the tires and applying the dressing, go over the RWLs with a common "over the counter" bleach-white tire cleaning product. I cant tell you the name of the particular product due to forum policy. Just look in any auto parts store and you will find it!
In addition to my earlier response, it looks like Duragloss has a similar product available here at Autogeek that will also get those RWLs to clean up nicely.
Non-yellowing Tire Dressing
Re: Non-yellowing Tire Dressing
The yellowing probably comes from any grime that is left on the dressing applicator. I use a Q Tip with rubbing alcohol or tire cleaner to clean the letters individually.
For BF Goodrich T/A Radials I prefer to use Tuf Shine Tire Coating.
In fact, in this last weekend's class we just machine cleaned some BF Goodrich Radial T/A's and coated them. They came out AWESOME.
Look like this only the Goodrich brand.
Here's the review I wrote, it's also a how-to
Review: TUF SHINE Tire Clearcoat by Mike Phillips
Here's a before and after shot...
Here's a full-on beauty shot....
(I rubbed out the original paint too)
But here's the deal. MY RULE for applying a tire "coating" (not dressing), is the tire can NEVER had a tire "dressing" already applied. Too risky to chance remove it all for a proper bond of the coating.
So for you, get the Tuf Shine Tire Cleaner, it's the best, I just used it yesterday here,
Review: BLACKFIRE Car Dryer
And then maybe try BLACKFIRE Multi-Surface Dressing Concentrate and use it full strength. It's water based so it's easy to wash off with soap and water and this means it's EASY TO RE-APPLY. And that's what really works best for tires like yours, something that works great, is easy to apply, is easy to remove and thus you now have a "consistent" maintenance plan.
Or go with some gooey tire gel that's impossible to get off and suffer through yellow and browning white letters.
Here's my review for the BF multi-surface dressing concentrate. Just by coincidence, this old 2-door MOPAR has a set of really trashed BF Goodrich Radial T/As
Try to find the above plethora of how-to info on a FB group with linear pictures.
From our experience testing tire cleaners and our tire clear coat, we have concluded that the anti-ozanants in the sidewall, which is an amber color, will bleed to the surface and make the letters turn brown looking. There isn't much you can do about it unfortunately. One thing we have tried is to use a white waterbased paint to coat the letters and then coat with our Tire clearcoat to protect the paint and seal it.
