Tire Stains on Leather
rott3np3anut
Hey guys. A friend of my mom's has a Toyota Sienna with leather seats. He folded down the seats and put a piece of cardboard over them, then transported some tires with the van. Apparently the leather slid a bit or didn't completely cover the seat, and there are some pretty set in stains on the back of the seat. A regular leather cleaner isn't working, what do you guys suggest?
Here's a pic
What have you tried?
OPC I feel would clean that up and its safe for leather.
The good thing is, it looks like it's just dirt from the surface of the tire and not the actual rubber.
Any APC such as OPC will work well. If once you get the dirt off you find that some of the rubber transferred, try the leather conditioner and it should lift it off.
Okay thanks guys! I was going to get OPC anyways with this memorial day sale. If not, the only APC I have is Meguiar's APC+. At what concentration is that safe for leather?
Thats super easy
Wipe the area with a damp towel (water)
Get a Magic Eraser and cut it into 1/3's. Soak the Magic Eraser (water) wringe out 75% of the water and spray your APC (straight) onto Magic Eraser. Now gentally glide it across the area and you will soon see that mark disappear
You wanna be sure and keep the area wet (water) that your working on
Good luck, and lets see those after pics
Flash :hungry:
you have to be careful rubbing magic eraser on leather imo.
On another forum, dude used it a number of times on his leather with no issues, then all of a sudden, bam, he was taking off colour and had a shiney spot.
Way I figure it, he must have been rubbing off the protective coating the first few times, then did the equivalent of burnthrough on that one spot... there's no going back from that so better to be safe than sorry.
:iagree: One can never be to carefull I suppose
Another thing you have to watch for is if its a used car that might have been re-dyed. If it has, theres a very good chance of doing damage if it wasn't prepped properaly
OP. If you choose to use the Magic Eraser, keep your surface wet, and glide ever so easily over the area your working on. Once you see how its working, you can lean get a little more aggresive if need be. Just don't go nuts with it
Keep it wet!
I agree if you use the eraser for this cleaning I highly doubt any damage will occur. If you use common sense not exceed pressure to "cut" into the leather you'll be good. IMO/IME
Try an alcohol cleaner as this will be safe. If this does not shift it it is unlikely that anything will without damaging the leather finish. Magic erasers should not be used to clean unless you are going to refinish the leather after as they will almost certainly remove the finish.
If alcohol cleaner does not remove the problem then the best thing would be to recolour and refinish.
Hope this helps
Judyb
Hope this helps
Judyb
Judy anytime I answer a leather question I think of you. I hope me recommending the Magic Eraser didn't cause your head to spin bachwards
I know your an expert on leather, and I hold your opinion above all others (forums), but I'm not real sure you can fully appreciate the abuse some of these daily drivers inncur. Sometimes you just gotta get nasty in these situations to gain any noticable difference
I admit, using a Magic Eraser wreaks of hackness, but believe it or not, if your very carefull they can and do provide amazing results
If like you say, "if traditional methods are getting you no where, you probally wanna consider a recolour"
My response to that is, "why not try" :p
You know I love you :kiss:
Flash
Hi
Thanks for the response.
I am fully aware of the problems that are caused and the havoc that is wreaked as I deal with it on a daily basis.
The reason that Magic Erasers give such good results is because they remove a layer of finish from the leather - this will make the leather look extremely clean but will leave it in a very vulnerable state which will then deteriorate even quicker.
As I said if you are going to refinish after you have cleaned then the Magic Eraser can be used.
Magic Erasers are made from very finely ground melamine and are a great abbrassive on hard surfaces but will provide the same cutting action on leather finishes which should be avoided.
Hope this helps
Mix up some APC about 10:1 or more to test, then go a little stronger if you need to. A soft brush to agitate it if needed, otherwise just microfiber to agitate. Should come right off with no problem.
Hi
Hope this helps
Well, just so long as your aware I love you, thats all that matters to me
Flash
Please! May I know the number of days, the tire were in contact with the leather?
Thats super easy
Flash :hungry:
i wouldnt use a magic eraser on any surface thats shiny, magic eraser is an abrasive and will take some of the surface off. i dont use it on shiny surfaces, i used it on my dash (before i knew what i was doing:P) and it made a "matte" spot while the rest was shiny. i put some megs WBD over it and you cant see the spot anymore. but yeah, i wouldnt use it on leather. if you do decide to use it, do a inconspicuous spot first.
personally id probably just use OPC and a MF after letting it sit for a minute.
Well, that means I am either luckier then you, or just better :P
Quick update
First of all, thanks everyone for the replies. I tried it last weekend with Meg's APC+. It didn't even touch it. I'll be placing an order soon and will get OPC, which people seem to have much better results with. Hopefully that works.
I do have a magic eraser, but I'm debating whether or not to use it. I do trust Flash's opinion though, so I'll probably do a test spot to make sure it's safe. It's just a friend's car, and he's in no hurry. I'll keep you guys updated.
Quick update
I don't give bad advice. Go for it man!!!
Just remember...let the ME do the work. Follow the advice I gave earlier and you will look like a magician too
