Totoland Mach
- Mar 3, 2006
- 1,142
This is the last car for April and wasn't too bad exterior-wise. I am using a process that's going to be standard for the shop because of the finished appearance.
Step 1: clay if needed
Step 2: wool pad + compound and work the area until glossy
Step 3: glaze with a glaze foam pad
Step 4: 3M Ultrifina SE and their blue pad
Step 5: Meguiar's #26
Here's the result of the above process. I'll probably have some black cars to try in May, so it should be interesting.
Sunset shots
Inside shots: the flourescent lighting plays tricks with the color rendition
April is done!
Toto
Sunset shots
April is done!
Toto
