A friend asked if I could remove the defects out of his 2007 VW Jetta. Yesterday I took out the Defelsko and the overall paint thickness was around only 100 microns or so. Now I only measured the trunk, but for the sake of discussion lets assume that number is consistent throughout. Would you guys consider that a little too thin to work on? I'm not entirely comfortable working on that even with a PCXP. I certainly would not take a rotary to paint that thin and I'd even think twice about using a Flex. Typically I would use either the PC or the Flex with UC or 105 on an orange pad, follow that with 205 on a white pad, then finish it off with 85rd on a black pad. That combo typically gives me good results. However 100 microns is thin and I'm a little tentative because of that. I realize it would probably be fine using a PC, but still thought I'd come over here to solicit some opinions. I may just end up using ColorX on a green AIO pad with the PC and/or Flex just to get rid of of the dullness currently in his paint. What do you guys think? Almost forgot to mention, this is a daily driver that currently sits outside 24/7. Thanks.
