Just did an 18 month old Rogue with Collinite Marque D'Elegance and it came out pretty good. The grayish paint didn't really sparkle though. Was wondering if I could've put BF SiO2 on top, or would it just be a waste of time/money?
Pretty much a waste. SiO2 over a wax doesn’t do anything special. Use a spray wax to maintain Collinite. After the Collinite wears off or you want to change the look try a coating or a coating lite product and top it with one of the multitude of SiO2 toppers.
Collinite Marque D'Elegance...
Phil
Can Si02 be used after BF all in one?
1) Not sure about second coat, will let someone else answer.so I have just applied the blackfire ceramic coating and am trying to figure out
1) do I need a second coat and if its been several hours between can this be done
2) the difference between the coating booster and the SIO2 spray and
3) which to use when any advice would be greatly appreciated
On a related note, I've been using the BF SiO2 Spray recently. Can I apply McKees Paint Coating over the top of it without removing the BF?
Silicon and Silicone are 2 different things.I would think that since s102 is a form of silicone, that it can go over or under any other silicone product. By the way polymers are also a form of silicone
2) The Booster is thinner. Some claim it’s hard to tell if it’s even adding value, it’s so thin. I myself can see an increase in glassy shine when applying it, but have no clue if it has any real longevity or not. The SiO2 Spray is much more substantial, way better as a standalone, can last weeks for some or months for others by itself. I believe this has a lot more sealant polymers than the Booster.
3) Pick one and go for it, don’t buy a gallon of each like I did. The SiO2 Spray is more popular and will probably alter the look and characteristics of your coating more while adding some decent protection, and I would think using it every 1-2 months max would be fine.
If you prefer your coating characteristics and look and only want a slight shine refresh without adding much durability/protection, I would recommend the Booster and you can use it probably as often as you want is my guess.
