To wipe or not to wipe
DogRescuer
Hi guys, when you are applying your LSP to say a hood or fender, do you apply and remove right away? I was wondering if I should still be using the 2'x2' method as I would a polish, and remove it pronto, or is it safe to finish the panel, and take my time removing my sealannt? It is M21 by the way. Thanks to all.
Depends on the item. Some recommend waiting to haze, some say wait 15 minutes or so, it's all dependent per product.
Usually the instruction on the bottle say what to do. However klasse is a pain in the butt to remove if you let it dry to a haze so I remove it right away. Follow the driections. If that doesn't work see if something else does the job better :)
Some waxes need to dry and haze, others are WOWO. What products do you have in mind?
M21 you can let dry. I do the entire car before I start the wipe off and it works very well for me. The pro in my local Mirror Glaze store told me to leave it on overnight, buff and second coat with a quicker removal in the morning for even better results. I haven't tried that though because I only have a carport and the car will get dusty and all overnight. I can't take a chance at swirling it out after my hours of correction.
