I could use a little help picking out a coating for a new truck. I think I want a ceramic coating, but I’m open to other options. There are so many choices, I’m just not sure which way to go. The truck is dark blue metallic, and will pretty much live in the Florida sun. I’m looking for something that provides excellent paint protection, lasts long, and is easy to apply. I’m fine with re-applying the coating every year, but would prefer not to have to do much more than wash it regularly and maybe use an occasional decontamination product. Price is not a big factor (within reason), and the more hydrophobic and glossy, the better. Any recommendations are greatly appreciated!
With proper care the coating can perform for a long time. In sunny areas a coating can make it to 2-3 years easily while still looking good. It is all about maintenance.
A majority of the gloss is going to come from the polishing process. Most coatings will appear the same in terms of gloss. If I gave you a panel with multiple coatings, you would not be able to tell me which is which. Yes some will give more of that glassy type appearance. And coatings have come a long way in terms of application.
You could look into any of the Autogeek house brands as they are easy to work with such as the blackfire pro black edition or the DP GR4 graphene coatings. As a matter of fact Wolfgang has 30% going on their own site that Autogeek can match.
These coatings are all easy to work with. You can not go wrong with any of these. These are my personal notes from testing them.
Gyeon Pure Evo - will darken paint with candy gloss
Gyeon Mohs Evo - slick. will not harden the applicator
Cquartz UK 3.0 - will darken paint.
CQuartz SiC - slick. will not harden the applicator
DP GR4 Graphene - will darken paint
Poorboys Ceramic - slick
Blackfire Pro Black Edition - cures hard on the applicator. Will sheet a little more than bead. Darkens the paint.
P&S Legend - not the most user friendly but surprisingly durable
Adams Advanced Graphene - slick. some complain about the tacky wipe off when leveling. Very hydrophobic
Adams Multi Surface Graphene (Original) - very user friendly
Gtechniq CSL - similar to mohs evo but not as hydrophobic as mohs evo. Tends to sheet more
22ple HPC - easy to work with and candy gloss. Will need a couple bottle as it is recommended to apply two layers
22ple Insanity - easy to work with and crisp gloss. Will need a couple bottle as it is recommended to apply two layers
3D Ceramic - Tacky and not that hydrophobic. Poor self cleaning effect.
Glassparency Graphene - similar to Adams original graphene with just a little more sheeting compared to it.
Coating Lites:
Gyeon CanCoat Evo - Very easy to work with and will exceed expectations
Cquartz Lite - applies like a typical coating but very durable. Not a slick coating.
IGL Poly - Easy to work with. Decent coating.
P&S Sole - Easy to work with. Peppermint scent. Good hydrophobics.
