Too much pinnacle glass sealant
Dewy
I used this for the first time and applied WAY to much. Should I clean with dawn or is there a better solution? Thanks for your help.
Less is more with Pinnacle Glass Sealant. I found that if you over apply it can be difficult to remove. I use small make up sponges and it seems to spread and product well and make it last.
I used too much also,my first time. I reapplied it and the streaks came out.
When you use too much, you can remove the excess with DI water and a towel.
