I recently removed the "TACOMA" side badges from my '09. I did the traditionally fishing line and pull method and then used label remover after. I couldn't get everything off and for good reason, it appears the glue, or maybe the badge etched into the paint-see pictures. I tried sanding with 2000 grit, buffing with m400 and then polishing it out, but it is still there.
Has anyone encountered this before with a resolution other than touch up paint? If I went the touch up paint route it'd be pretty extensive.
How can can I fix this as simply as possible?
Sanded
After buffing, just next to the shadow you can still see everything.
Other side wasn't as bad, but nonetheless.
Sanded
