toothpick and qtip
animescreen
I tried searching toothpick but didn't see answers i was finding so i post yet again! I seem to be able to use toothpick really as a universal way of getting things in out in very tight areas or put it under mf towel to get junk out... I usually flatten the tootpick a little so it doesn't scratch the car but it's always at nooks and crannies anyways so shouldn't matter... Also use qtip for "fatter" jobs... Obviously qtips are ok since it has softness to them but how bout toothpicks? anyone use this for lot of there tasks? (it's cheap and if you have something in your teeth you can use the other end Im the MAN
I had these roll of dirt and grim in tight area that i never cleaned .. used meguiar detail spray to soften it up then used toothpick and got 90% out.. i'll just leave the 10% or i'll turn ocd. I also use it when i wax and the wax gets in the gaps..
Or should i get a type of kit with toothpick type points to get these areas cleaned...? if yes let me know what kits you got! (various tips etc..)
