Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
Top 3 Tips/Techniques that helped the most when first starting out?
Thinking back to when you first got into detailing cars, what are the top 3 tips or techniques that helped the most to get the results you're were struggling to get?
When I first started out, someone showed me,
1. How to pick up a bead using the 10 @ 10 Technique when using a rotary buffer. This helped a lot compared to what most people do and what I was shown which was to with the rotary buffer "off", take the pad and spread a glob of product around on a panel and "then" turn the buffer on and start buffing. This also tends to sling splatter everywhere.
2. How to use a real steel pad cleaning spur to clean my wool pads instead of a screwdriver.
I've used screwdrivers as well as other things to peel off the gunk that builds-up on a wool buffing pad when compounding, but a simple tool like a steel spur, a tool designed to clean and fluff the fibers works so much better.
3. Using firm downward pressure with a Porter Cable to remove swirls.
When the Porter Cable was first introduced to the paint polishing world from the wood sanding world, back then everyone kept saying just use light downward pressure. Everyone was saying,
Just use the weight of the tool.
Of course, this was over 20 years ago. I found this advice in practice meant never actually getting any work done, in other words, never actually removing swirls and scratches. On my own I tried pushing down hard, or firmly while still maintaining pad rotation and voila! The tool actually started working.
No one showed this to me, I figured it out on my own and then started showing everyone else. But this helped a lot for removing swirls when using a DA polisher as well as turning out hologram-free finishes after using rotary buffers. We also didn't have all the cool abrasive technology that's readily available today.
Keep in mind back when the Porter Cable was introduced, there also were no thin foam buffing pads like we have today, everything was actually fairly thick and this too, hindered the Porter Cable and PC "style" tools. Marking the back of a DA backing plate to make it easier for your eyes to monitor if the pad was rotating was also a key technique that helped me and others as well.
So what tips or tweaks in your technique helped you the most when you first started out?
