Maybe I can help
rops:
I use my Tornado Black both at home and at the dealership. The dealership uses a massive air compressor (I don't know its specs) at home I use a small 5gallon unit with the Tornado Black and see NO difference in performance from moving between the two. With the 5 gallon at home I gets 3.5 SCFM at 90psi, if I remember correct. I can normally do what I need to do on the exterior and interior of the car with the compressor turning on 2 or 3 times max during the process.
Couple points and thoughts about the Torando products...
- I use to use the original Tornado also, but I use it ALOT and the spinning ring inside would cut the white plastic to dangerous levels.
**Yes the make replacements tips and even a replacement with steel inside - but at that price and replacements I just bought the Black, much more economical (the tip no longer hits the plastic housing which I would have to replace)
- The Tornado Black is MUCH more powerful and MUCH quieter, I've found in my use.
** the tip on the Tornado Black doesn't hit the plastic housing which makes it so much quieter. There is enough noise in the body shop!!
-Also I can attach the foam tip to it and volia... I have a foam gun!
** I use my Black Tornado for everything I can...
1) Foam gun
2) Deep carpet cleaning
3) Leather cleaning
4) Drying of crevices after exterior wash - No leaf blower need. I also use my compressor needle pointer attachment once in awhile, but mostly the Tornado.
5) Also use to blow out body shop dust on the car before cleaning or vacuuming.
Hope this helps you out Gene!! :dblthumb2:
