AeroCleanse
- Nov 17, 2008
- 2,422
Is is possible to upgrade the white tornador to the black one?
Best to contact tornador but I'm pretty sure the answer is no. The parts are not interchangeable.
Sent from my SAMSUNG-SM-G900A using AG Online
Here are exploded views of the Tornador White (Z-10) and Black (Z-20)
Most of the parts are the same with the exception of:
On the Tornador Black the numbers for the following are different:
- #4 Hose
Not sure why they call it a hose on the diagram?
Looks the same
Can be purchased as a replacement part (Tornador Valve Body)
- # 11 Nozzle
I suspect they are just different colors
- #21 Inner Tube Assembly
Looks the same, But, I suspect the Black one is shorter
In the videos online, it looks like this piece can be trimmed
- AK Rotate Set
This is what I suspect gives the Black it's added power
Threaded potion looks same as on White
- #25 Gasket
after seen what you posted you got me wondering if we can just buy the classic and just buy the pieces to upgrade to the black... would be less expensive... lol..
Assuming the pieces are interchangeable....once you buy the parts, the two machines are about the same price
what company makes the kit?
