AeroCleanse
- Nov 17, 2008
- 2,422
Is it possible to upgrade a Classic Tornador to a Tornador Black but replacing the rotating assembly and cone?
Feed back please
Feed back please
Feed back please
Main thing is "don't damage your tool"..... LOL :iagree:The best thing to do is contact Tornador themselves to see what can be field upgraded or not.
Buy Genuine Tornador Car Cleaning Tools and Parts Here
Tornador Tools: 972-248-8542
In looking at my Tornador Black there is a rotation replacement kit found here:
TB-200RS
Here is a pic of mine with the cone removed. If yours has a similar assembly nut, I don't see why you can't order the part and replace it on yours.
With that said, you should check with Tornador first to ensure that:
a.) you do not damage your tool;
b.) you do not modify it in a way that can cause harm to yourself or the vehicle you're working on.
I hope this helps.
I checked with Tornador and you can upgrade it.
1. TB-600 Inner liquid tube
2. TB-404 Valve body
3. TB-200 RS Rotate set
4. TB-100 Black Cone
5. CT-023 Screw Sometimes these are difficult to salvage, if it is difficult to remove apply heat to loosen the thread locker, good for a back up
6. CT-228
Hope this helps
Dennis
So it's possible but maybe not worth it. Guess I'll keep using my Gen 1 until is breaks or something.
What is the combined cost of these parts versus buying the "Blastor" upgrade?
