Toro Leaf Blower for Car Drying
Kurt_s
Well guys,
I broke down and bought the 235MPH Toro leaf blower and gave it a try. The Toro unit is heavier than I expected but it was kind of fun to us. It helped blow water off the paint surface with a little practice and out of crevices but never completely blew water out of my wheels, around the trim or from all the crevises as I expected. This is a car that beads exceptionally well with WG sealant base and an OCW topper on it. I use a final rinse of soft water from a hose without a nozzle to sheet water off the paint surface before drying.
I have two major issues:
1) I strained my left shoulder from the weight and sometimes awkward angle after using the blower
2) I really couldn't use a towel and the blower at the same time
3) I was tethered to an electrical cord
4) I noticed when blowing the water droplets off the car, very small white spots remained on the paint from tiny residual water specs. The surface appeared lightly powdery in some areas.
I needed a detailer spray (OID) to remove the cloudiness from the paint surface. I had never experienced this issue when drying by hand and I've quickly dried many cars in the sun over the years before pulling them in the garage to finish up.
The outcome:
My shoulder is still healing 2 weeks later and my poor car needs a bubble bath. :cry: The Leaf Blower went back to HD. I think I need a couple more WW MFs for hand drying.
My questions:
1) Have others experienced this spotting effect when using an air drying device?
2) Is there a easy to store, easy to use, lightweight but powerful tool to blow out water from crevises, trim, wheels and under emblems in the $70 range like the Toro, and still handle a WWMF towel at the same time?
3) Will there be a 2 fer BOGO for larger size WW MFs soon?
Thanks!
Get a smaller leaf blower, you don't need but around 100 mph to blow water from nooks and crannies. I have a Makita cordless, but it's around 200 bucks with battery and charger.
My questions:
Thanks!
How's this for a handy blower? 80$
http://www.autogeek.net/metro-blaster-sidekick.html
  • Air Volume: 160MPH/85CFM
  • Air Speed: 18,000 FPM
  • HP Motor: 1.3
  • Amps: 8
  • Volts: 120
  • Watts: 950
  • Warranty: 1 YEAR WARRANTY
  • MADE IN USA
Thanks. I saw another cordless at HD for about $100 that put out around 100MPH. Good to know that 100MPH will work.:dblthumb2:
I was wondering about a smaller handheld as an option. I think CG sold one and I think there's a bike dryer on AG. I'm good with hand drying large surfaces but a nice blower for nooks and crannies would be great. I can never seem to get the side mirrors and my rims dry, which is a pain when I want to polish and wax immediately.
Just drive it around a few blocks.
  • HP Motor: 1.3
  • Amps: 8
  • Volts: 120
  • Watts: 950
  • MADE IN USA
Thanks CEE DOG! Just might be the ticket. I live in SoCal so I don't get to Florida to try cool stuff at Detailfests. Do you use the sidekick?
I've also been on the bubble to buy an air compressor. There are a few jobs were it would be handy.
I used to years ago but stopped. I wondered if I was getting dust, dirt and bug bodies on the freshly washed paint before claying, polishing and waxing. Heck, in the spring it's hard enough to keep it clean after washing with the pollen blooms.
Glad I don't have that problem. BTW I called AG sometime age about the blower and they told me it doesn't have much power. The Makita is pricey, but a joy since it's cordless.
Thanks Rsurfer. One of the reasons that I love AG and this forum is I get real life experiences and recommendations in real time. :dblthumb2:
take care!
No, I haven't tried the sidekick. I've been looking at the Metro Master blaster which I did get the chance to try at DF. The Metro MasterBlaster is Metro's most powerful blower/dryer at 8hp! Blow dry your motorcycle & your vehicle with this big blower.
I'm waiting for it to go BOGO to split the price with Bunky :D
Currently I use my air compressor to do crevices, mirrors, tires, wheels. Then on the paint I use WW towels with either OID, FK425, AW, or OCW. Just started experimenting with the FK425...
CEE DOG, Hmmm... FK425?
I used to dry with a synthetic chamois and a particular vendors ID that was compatible with their wax. I still love their wax but there are better IDs.
I started using OID earlier this year with wonderful success (slick, shiny and bright on a white surface) after removing water with a WW MF and applying with a dry MF. I recently tried OCW after drying without the OID. OMG... Best of sealant and carnauba heaven?
What's the difference between the FK425 and OID? I tried the pink CG synthetic detailer that looks like the FK425 with ok results. Too much streaking for me.
FK is slicker, but OID is cheaper.
Wow. OID was slick after application but was significantly slicker 24 hours later.
I may have to get a trial size of the FK425 for laughs and giggles.
Thanks!
"235MPH Toro leaf blower"
WOW, I'm surprised you didn't blow the paint right off your car with that thing :laughing:...I rinse w/ CR spotless, and blow dry with a cheap Black and Decker leaf blower (around $45.00) . Works great even on black, absolutely no problem!
Well the neighbors house is down the street somewhere. At least what's left of it...:laughing:
I didn't expect the residue as I've used soft water for 4-5 years and hand dried. The Toro was too heavy and unweldy, and I'm not a little guy. Maybe a cordless makes better sense for what I want to do?
I found FK 425 streaky..... and cant imagine it being slicker then OID.... I am definitely gonna have to revisit it if you say it's slicker... OID is SLICK
This is new to me... why would you use a leaf blower to dry your car? You have a greater chance of blowing some dirt or something on your paint which could eventually get on your pad or mf while buffing... leaving major scratches, right?
The op knows how to use the flooding method, so there is not much water left on the paint. The main reason for the leaf blower is to get water out of the nook and crannies.
Rite on! I use the flooding method too but use the 5MPH lung blower which doesn't last too long and get into the hard to reach places... something to look into. Thanks! :xyxthumbs:
Done that for years, but since upgraded.
