Touch-Up Front Bumper Cover; Kia Soul
2black1s
Did a little touch-up job to my daughter's Kia Soul. Someone hit and gouged the front bumper cover a month or so ago... No idea who or even where.
Start to finish took about an hour. Perfection was not even a consideration. This was simply a "make it disappear at 10 feet" repair. In fact, the paint I used wasn't even color code specific... It was a spray can of Rustoleum Gloss White Fast Drying High Performance Enamel that I had on the shelf. Sprayed it into the cap and applied with a brush. Color match was actually pretty close.
Far from perfect, but my daughter is happy.
Process:
- Trimmed away the raised material with a single edge razor
- Compounded the repair and surrounding area w M105
- Cleaned repair area with Isopropyl Alcohol
- Filled the gouges with JB Weld Quick
- Trimmed and leveled the JB Weld with a single edge razor and swab dampened with acetone
- Applied the touch-up paint
BEFORE
AFTER
Is JB Weld like Bondo? BTW nice job.
Kind of, but much stronger in a thick application. I have actually used this to repair stripped female threads in a light-duty capacity.
It won't replace a Heli-coil, but it's some tough sh!t.
I always have some on hand in my shed/workshop.
Went out to grab it to show you:
This is MarineWeld, but there are different variations. Awesome stuff!
JB Weld is an epoxy. Not my number one choice for this type of repair but much better than Bondo. It's what I had around.
Ideally, I would have used 3M Flexible Parts Repair Material but I didn't have any on hand. It's also an epoxy type material although it remains somewhat flexible when cured... Moreso than the JB Weld.
Great job fixing your daughters Kia Soul.
