Touch up pen
Rsurfer
Active member
Has anyone used the touch up pen that has a reservoir on the top? Is it really that much better than using a fine artist brush?
Are you talking about the pen on one end and brush on other?
I could never get the paint to flow out of the pen.
The best I found is a paint code bottle dabbed onto a baggie and the fine artist brush. You can dab and practice on the plastic to acquire the right amount on the bristles.
Me either. I even got a new one from my dealer, and it didn't work either.
No, this has a small paint reservoir on top that feeds the pen.
No clue what you are referring to then. I did some quick searches and couldn't find anything like that.
I am curious once again.
Go to Amazon and search auto paint pen. Tried to copy the picture, but couldn't copy it.
I enjoy working with Dr. ColorChip, so I've never tried the Rock Chip Touch-Up Tool. I've only seen videos of them being used on social media. Looks like a pretty cool tool though.
Are you talking about Loew-Cornell Fine Line Painting Pen? That was brought up by Larry from AMMO a while ago and went viral. I have used it and it does work great. I just hate cleaning it up afterwards as the reservoir and tip are tiny. But it does work well for those tiny rock chips.
If that's not it, then I don't know what you're talking about.
Thanks that's it. The pen I saw came with a fine brush for cleaning. Don't know if it makes cleaning easier. I have a paint chip that I had a PDR guy remove the dent, but the rock removed the base coat.
Because of the size, I was wondering how the pen point would spread out the paint. Does the paint self level within the chip?
It does come with a pick to help clean it but it’s not super easy. But the tool works.
If the chip is more than a tiny dot, you can tap this “pen” in there several times and each time it dispenses a little bit of paint. Sort of levels itself.
Dr Colorchip also works well. And I’ve used that paint with the pen and it was fine. The nice thing about the pen is that it doesn’t lay down a blob. It’s pretty delicate and helps achieve a precise result. Probably works best on horizontal-ish surfaces. Vertical ones can be trickier with any touch up.
I have used both the pen and the brush. I like the brush better even for the smallest rock chip. I find the pen too hard to put on evenly while a brush you can control how much you put on.
Yep, found it.
I like my brush approach or out comes Dr.Colorchip.
Seems to me lacquer thinner would be better at cleaning that tool than alcohol(watched the AMMO vid)
I'm concerned because the chip is rather large. 1/8" in diameter.
I’ve never had good luck with the ballpoint touch up tips.
I prefer buying inexpensive fine tip paint brushes in the craft aisle at Walmart. I Clean them up after every use with paper towel and paint thinner. The brushes have nice sleeves to keep the bristles straight and true.
Now if I could just get my tri-coat pearl white paint to blend/match the original paint:(
If you get a magnifying glass and stay within the chip it works out great. Get paint outside the chip and it looks like crap unless you wet sand.
I will never wet sand OEM paint again. Give you one guess why.
When that happens with me...I let the paint dry for a while until it is just dry enough (kind of tacky, but a pin won't go in too easily), and then swipe it with a real thin fabric (actually, I have been using these makeup cloth removers, but have used old cotton t-shirts) wrapped around a somewhat pliable foam block, soaked with a bit of paint thinner (or mineral spirits).
If I'm careful enough, it removes the high spots, without affecting the fill. If the paint hasn't cured enough, though, I wind up taking off the fill itself, but then it's just easy to start over from scratch again.
Eric
I have that paint pen and I personally love it. Works great on multiple tiny chips. But the Artist brush works good to just depends on your price point. I also used tooth picks.
How about a fine eye dropper? I think a little wet sanding my be needed filling a chip that big.
