Touchless wash in freezing weather
frankprozzoly
I'm concerned about running the car through a touchless in this cold weather. It drys the car fairly well but obviously doesn't get underneath. Am i just being paranoid
Sent from my SM-G900P using Autogeekonline mobile app
Most touch frees have underbody washing
No you're not. I won't run my car through a touchless wash unless the temps are above freezing. High pressure sprayed water gets into all sorts of places I don't want it to freeze and cause problems.
Two weeks ago I traveled for work and the rental car place had just washed the car they gave me. All of the doors and the trunk were frozen shut because water got around the seals and turned to ice. The wipers were frozen to the windshield and the external mirrors were covered in ice as well. It was a big mess the caused niggling problems for the entire time I had the car.
FWIW, I've been using touchless washes with the under carriage option for many winters here in Michigan and I never had a problem.
When the temps drop well below freezing here in NH I stop bucket washing and use touch free as I have for years and have never had a problem. I just open the doors/trunk a little while after the wash to be sure they don't freeze.
Frank
I just did mine last week when it was 5* out. after I pulled out I opened the doors & made sure the saddle & rubber gaskets were dry. it was pretty much dry from the blower but I used a towel & gave just the door jams a once over. the only ice that remained was on the wheel covers. we also do my wife's car with no problems. the only thing I'd be worried about is opening the doors next morning. I say do it. it won't look detailed but you'll knock off a lot of that slush & salt. if you've got a garage you can do a rinse less wash also. good luck.
hmardown
In line for my basic touchless wash with drying now
Sent from my Galaxy Note 8 using Tapatalk
One of our two touchless washes has a Laserwash brand machine. Your wash looks about 15-20 years newer. I especially like those three jets that accompany the underbody flush. That would help clean off the rocker panels. Ours is missing the three jets
Ya door and trunk seals are the major issues when washing the car in winter. If you decide to do it, make sure to have a towel ready to wipe the seals dry afterwards. Also you can apply silicone protectant to the rubber seals to prevent them from sticking to the pannels. Something like Meguiar's All Season dressing should work well.
303 makes a great product for rubber seals!
Look closely at the Jets on the floor as they spray upwards in the angle from each side too
Its my understanding that touch free places use high ph soaps that strip your protection. I have, but will never again use one.
I use the pay and spray in the winter, either take my buckets with me, or just use the high pressure rinse, never any soap or wax settings. Then come home and do a rinsless or waterless, depending upon whats leftover.
Most self serve wand washes around me would kick you out and tell you to never return if you pulled out a couple buckets and proceeded to bucket wash while in their bays.
About 4 washes through the touchless and my LSP (Fusso Coat) is still holding strong. Some washes probably do use stronger soaps. Mine is so weak it doesn’t even get off all the dirt streaks.
I like your method the best. Our coin-op wash has been closed two years now. Otherwise I would use that with my own wash buckets.
On my way to the VA last week I shot this clip going through a local touchless.
And here is a pic I took after I got there.
Here is a shot of how that side looked a week earlier.
Not bad for $5
My car is coated. I have no worries about the ph or soaps.
I've never had issues with the soaps striping my LSP.
I've used Klasse SG, Collinite 845, and now McKee's 37 Paint Coating. All of them were subjected to multiple touchless washes from multiple locations across and all of them survived with no issues. The degradation I saw was no different that what I saw from hand washing over the same length of time. That isn't to say the soaps aren't harsh, but only the LSP's were quite durable and could take the punishment.
