WorldMattyBlue
- Nov 11, 2016
- 17
I finally tried the EX 04-06 for the first time and had very mediocre results. A lot of elements here so I'll try to keep it short. It's a daily driven BMW 5-serires. I wanted to try something new going into this winter, so i went with the Sonax EX 04-06 and Chemical Guys Hex-Logic green pads. I've used my PC 7336 for close to 15 years so i'm familiar with the machine, but the pad/polish combo is new for me. Car was prepped as i normally would - wash, decon, clay, and prep spray.
During the test spot, application went smooth, nothing out of the ordinary. When wiping clean, it didn't immediately buff off and I had to really work the towel. I tried using less product, and more product, same results. I tried a new test spot, again had the same results. I increased the machine speed, no luck. I tried working with fewer passes, and then more and longer passes. Same outcome. Pads were blowing out clean and as expected.
I broke out some Megs Ultimate Compound with a fresh pad, and tried on the same spot, and a new test spot and it buffed out clean and easy both times. Immediate reaction was that the Megs seems like you're working with more product, something i never noticed until the back to back with the 04-06. Sonax was still visually there, but it was much harder to see the product, even when i increased the amount used.
The Megs also gave a better result, better cutting and better finishing.
Questions:
1. Think it's possible i was still using too little product?
2. Could i have been working it too long, or too short?
3. Pad/polish combo not ideal?
4. Is this expected behavior?
Any thoughts or feedback?
Thanks!
Questions:
Thanks!
