Toyota Axio in for an enhancement
zckid
Hello friends!
Greetings from sunny Mauritius :props:
This car needed an uplifting, it really needed one even if it appears so nice.
Wash & decontamination
Claying the upper surfaces
Tar spots, plenty of them inn the lower areas
OMG! :eek:
All surface clayed, car has been rinsed and now starting with the glass
Water spots, no clear view
wiper marks smearing
After
To the paintwork:
Heavy swirls
S_C_R_A_T_C_H_E_S
more
and more
and plenty of them
The long term effect of bird droppings
Plenty of bird poo stains under fluorescent light
Heavy correction by way of damp sanding, taking care of the famous orange peel too
Improved
More scratches..... Deep ones.... clear coat and paint gone
Improved
More correction work
Thorough inspection and marking of remaining isolated defects
90% + defects removed
https://lh3.googleusercontent.com/suzm-dayMygw4F-2d2oCnfyvMWg72KHvdr37bwuDFAo=w748-h561-no
The sun test
Holograms after heavy correction. These were taken care of with the finishing step.
[IMG]https://lh6.googleusercontent.com/-wzEXNoqQPxg/VASx7lzJeSI/AAAAAAAAFNM/KPaqaJ19fJI/w748-h561-no/045.JPG
Remember
50 -50
TA DA
Roof refined
Same for hood and other sections but with limited pics since the job was finished late at night.
Thanks for being with us. Your comments and thoughts are most welcome. :dblthumb2:
Zaid
Great work! Looks totally different now:)
Thanks a lot Sicoupe :dblthumb2:
Talk about a make over! That paint was trashed! Beautiful work.
What was the process?
Thanks a lot Mike :dblthumb2:
the process is as follows:
wash:
2BM method, mf washmitt, local car shampoo & APC mix
after wheels were cleaned and decontaminated with Sonax Full Effect
Paintwork Decontamination:
Bilt Hamber regular clay
To remove the tar from the lower parts of the paintwork, I used the Sonax full effect. it worked
there were plenty of tar spots
Car was rinsed and inspected. In the sun, only swirls were visible. actually the swirls were hiding many defects, bird dropping stains, orange peel, loads of scratches.
I proceeded with some wet sanding, mirka 1500 grit.
I took the DA used the mirka 2000 and 4000 sanding discs.
:buffing:
Makita, LC & Sonax pads and Menz FG 400 and 203s
I spent more time on the correction stage to ensure that no traces are left. this made refining easier.
Topped the paint work with Collinite 476.
Glass:
DP glass restorer/Sonax profiline glass polish on carpro rayon glass pads
Trim was treated with CG new look trim gel
Tires had a local dressing applied
:xyxthumbs:
